查看: 413|回复: 0
EDA扩展版-V1 资料
    发表于 2023-10-17 15:58:33 | 显示全部楼层 |阅读模式
    EDAV1正面
    EDAV1正面
    EDA-V1管脚分配表
    EDA-V1管脚分配表
    1. #EDA-V1扩展板接AC620开发板摄像头接口管脚约束脚本
    2. set_location_assignment PIN_L7 -to SW[0]
    3. set_location_assignment PIN_P3 -to SW[1]
    4. set_location_assignment PIN_N5 -to SW[2]
    5. set_location_assignment PIN_M2 -to SW[3]
    6. set_location_assignment PIN_N3 -to SW[4]
    7. set_location_assignment PIN_M6 -to SW[5]
    8. set_location_assignment PIN_R7 -to SW[6]
    9. set_location_assignment PIN_T2 -to SW[7]
    10. set_location_assignment PIN_P1 -to Led[0]
    11. set_location_assignment PIN_T7 -to Led[1]
    12. set_location_assignment PIN_K10 -to Led[2]
    13. set_location_assignment PIN_P8 -to Led[3]
    14. set_location_assignment PIN_M7 -to Led[4]
    15. set_location_assignment PIN_T6 -to Led[5]
    16. set_location_assignment PIN_N6 -to Led[6]
    17. set_location_assignment PIN_P6 -to Led[7]
    18. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[0]
    19. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[1]
    20. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[2]
    21. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[3]
    22. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[4]
    23. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[5]
    24. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[6]
    25. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to SW[7]
    26. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to Led[0]
    27. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to Led[1]
    28. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to Led[2]
    29. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to Led[3]
    30. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to Led[4]
    31. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to Led[5]
    32. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to Led[6]
    33. set_instance_assignment -name IO_STANDARD "3.3-V LVTTL" -to Led[7]
    EDA扩展板-V1.pdf
    156.68 KB, 下载次数: 57
    EDA-V1原理图
    GMT+8, 2023-12-3 02:59 , Processed in 0.157212 second(s), 34 queries .
